发新话题
打印
excite报错,大家帮我看一下
excite报错,大家帮我看一下
$ Warning (Code 2430004)
Joint MainBearing1_01:
The distances of the connected nodes of the defined NONL joint differ
more than 0.1 percent. This may cause convergency problems in
the simulation.
$ Information (Code 2430005)
Calculated distances of the connected nodes:
       Maximum distance:   51.201
       Minimum distance:   51.138
       Average distance:   51.169
共有这样的类似错误15个。
Maximum distance:   51.201 指什么?
还望大家指点!
TOP
按下图填入
附件: 您所在的用户组无法下载或查看附件
TOP
谢谢您!我按您的建议试了一下,仍出现如下warnning
轴瓦节点在同一圆柱面上
主轴筋节点也是在同一圆柱面上
主轴承间隙为0.3mm(直径)
我的机体网格有17W 曲轴1.2w
是不是电脑算不了的缘故?
请蓝博士和各位大侠赐教
        the simulation.
              Maximum distance:   26.075
              Minimum distance:   26.011
              Average distance:   26.043
TOP
是轴瓦网格不精确所致,请手工将它们调整到精确位置。
不知你的发动机为什么“主轴承间隙为0.3mm(直径)”这么大,是船舶柴油机?
TOP
谢谢蓝博士!
1.主轴承间隙已跳整为0.005mm,我没有图纸,不知道一般汽油机或柴油机间隙多大?
2.电脑配置2.6G,2G内存 机体节点16W 曲轴1.2W,不知道excite pu仿真能否进行?
3.同时仿真时有遇到以下问题,不知道是何故,还望蓝博士指点。
%EXCITE-INFO, FC_StdIO, resetting max StdIO segment file size to 2000MB
$ SOLV Step/Time: 0/0.000000 s: 0/0 -> 0/0/0/0/0/0/ok
$ SOLV4  Body: 1@
$ SOLV4  -> Effective stiffness matrix: [ok]
$ SOLV4D -> Inversion:                  [ok]
$ SOLV4  Body: 2@
$ SOLV4D -> Factorization:              [ok]
$ SOLV4  Body: 4@
$ Warning (Code 3940002)
        Pivot coefficient (element (64,64)) is less than zero or
        loss of digits happened (  0.0000).
        This may cause numerical problems in factorisation.
$ Error (Code 3240005)
        Body Engine:
        The effective stiffness matrix is not positive definit or the loss
        of significant digits is higher than 6 digits during the factorization.
        User action: (1) Check the bodies stiffness and mass properties as well
                         as the defined integration parameters.
                     (2) Check the animation of the body.
$ EXCITE-7.0 - terminated abnormally!
$ FLEXlm Info: checking out license excite_crankshaft 7.0
TOP
1、“主轴承间隙已跳整为0.005mm”好象又太小了点吧,具体请查图纸,最好不要随便估。
2、Pivot coefficient (element (64,64)) is less than zero or
该模型的网格质量不好。
TOP
谢谢蓝博士!模型可以运行了
问题出现在轴瓦网格单元属性没有定义,读入pantran后只有节点信息而无单元信息,问题已解决。
在此表示感谢!
TOP
发新话题
Google
搜索 WWW 搜索 SimWe.com
baidu
搜索 WWW 搜索 SimWe.com
