发新话题
打印
继续请教蓝博士关于模型缩减的问题
继续请教蓝博士关于模型缩减的问题
蓝博士,换了一台机器不再出现磁盘空间不够的情况了,可能是机器的问题
可是又遇到了以下致命错误:
** FATAL ***                           CP=   2241.125   TIME= 12:03:45
An allocation was made with a negative length requested: -37611
Blockname:GOA.
这是怎么回事呢?谢谢蓝博士!
TOP
不知这个allocation是内存分配还是什么。
总之,先将你的系统和ansys调整好了。
还有,我试的计算机有2G的内存。
[ 本帖最后由 DrLan 于 2007-1-16 22:21 编辑 ]
TOP
我又试了一台机器,也是出现这样的毛病,这台是1g的内存
/COM,ANSYS RELEASE  8.0    UP20030930       21:06:03    01/16/2007
*** WARNING ***                         CP=     81.359   TIME= 21:08:05
*DO loop FVAL value is undefined: (_GRMAX1).  Using default (0).
No *DO trips needed, enter *ENDDO .
*** WARNING ***                         CP=    147.281   TIME= 21:09:26
Use of DIRECT for Direct Assembly of Equations is an undocumented
option.
*** FATAL ***                           CP=   5068.578   TIME= 02:06:03
An allocation was made with a negative length requested: -5125671
Blockname:GOA.
The above error is non-recoverable by ANSYS
  ANSYS run terminated by the indicated error
  Current data base saved if possible.
TOP
另一个模型是这样的:
00265231          VERSION=INTEL NT      09:40:36  JAN 17, 2007 CP=   1404.703
Note - This ANSYS version was linked by Licensee
  ***** PARTICIPATION FACTORS FOR WAVE EXCITATION *****    TABLE NO.    1
  MODE   VALUE      MODE   VALUE      MODE   VALUE      MODE   VALUE
    1 -0.28897E-02    2 -0.24866E-01    3  0.55814E-01    4  0.41928E-02
    5  0.26058E-02    6 -0.68198E-02    7  0.17071E-02    8  0.30249E-02
    9 -0.14715E-01   10 -0.27347E-01   11 -0.98171E-05   12  0.28083E-05
   13 -0.27519E-05   14  0.12825E-05   15 -0.11680E-03   16 -0.25171E-04
   17  0.21230E-09   18  0.14077E-07   19 -0.94093E-03   20  0.32158E-09
Solution Preparation Element= 1000 Cum.  Iter.= 190 CP= 1404.719
  Time= 0.0000 Load Step= 2 Substep= 170 Equilibrium Iteration= 0.
Solution Preparation Element= 49000 Cum.  Iter.= 190 CP= 1405.844
Solution Preparation Element= 86000 Cum.  Iter.= 190 CP= 1406.891
***** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 8.0     *****
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:41:11  JAN 17, 2007 CP=   1409.969
    1 -0.14714E-02    2 -0.13861E-01    3 -0.32108E-02    4 -0.68420E-01
    5 -0.13227E-01    6 -0.98536E-02    7  0.31654E-03    8 -0.12248E-02
    9 -0.10829E-02   10  0.11172E-03   11 -0.76205E-06   12  0.15336E-06
   13 -0.12921E-06   14  0.33622E-07   15 -0.26730E-05   16  0.38752E-06
   17 -0.88930E-11   18 -0.14806E-08   19  0.12946E-03   20 -0.50471E-10
Solution Preparation Element= 1000 Cum.  Iter.= 191 CP= 1410.016
  Time= 0.0000 Load Step= 2 Substep= 171 Equilibrium Iteration= 0.
Solution Preparation Element= 39000 Cum.  Iter.= 191 CP= 1410.969
Solution Preparation Element= 74000 Cum.  Iter.= 191 CP= 1411.750
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:41:48  JAN 17, 2007 CP=   1415.062
    1  -2.0371        2  -6.5765        3   13.023        4   1.6485
    5  0.26408        6  -1.7780        7  0.38541        8  0.28391
    9  0.65842       10   1.0096       11  0.15613E-03   12 -0.42138E-04
   13  0.40744E-04   14 -0.18543E-04   15  0.16850E-02   16  0.36434E-03
   17 -0.31633E-08   18 -0.25996E-06   19  0.20667E-01   20 -0.68134E-08
Solution Preparation Element= 1000 Cum.  Iter.= 192 CP= 1415.125
  Time= 0.0000 Load Step= 2 Substep= 172 Equilibrium Iteration= 0.
Solution Preparation Element= 47000 Cum.  Iter.= 192 CP= 1416.250
Solution Preparation Element= 83000 Cum.  Iter.= 192 CP= 1417.109
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:42:30  JAN 17, 2007 CP=   1420.031
    1  -1.0379        2  -11.750        3  -7.0072        4   4.4661
    5  -1.0959        6 -0.22820        7  -1.1435        8  0.11355
    9  0.91191       10 -0.53677       11 -0.11646E-04   12  0.29238E-05
   13 -0.27437E-05   14  0.11305E-05   15 -0.10080E-03   16 -0.14359E-04
   17  0.33728E-09   18  0.10803E-07   19 -0.73106E-03   20 -0.84314E-09
Solution Preparation Element= 1000 Cum.  Iter.= 193 CP= 1420.047
  Time= 0.0000 Load Step= 2 Substep= 173 Equilibrium Iteration= 0.
Solution Preparation Element= 49000 Cum.  Iter.= 193 CP= 1421.312
Solution Preparation Element= 81000 Cum.  Iter.= 193 CP= 1422.203
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:43:05  JAN 17, 2007 CP=   1425.312
    1   25.283        2  -3.4676        3   2.2100        4  0.16252E-01
    5 -0.46168E-01    6  0.23663        7 -0.17904        8 -0.58929E-02
    9 -0.92361E-01   10 -0.30241       11 -0.75385E-04   12  0.22680E-04
   13 -0.22559E-04   14  0.10908E-04   15 -0.99887E-03   16 -0.22943E-03
   17  0.19616E-08   18  0.12990E-06   19 -0.82220E-02   20  0.21406E-08
Solution Preparation Element= 1000 Cum.  Iter.= 194 CP= 1425.344
  Time= 0.0000 Load Step= 2 Substep= 174 Equilibrium Iteration= 0.
Solution Preparation Element= 45000 Cum.  Iter.= 194 CP= 1426.375
Solution Preparation Element= 77000 Cum.  Iter.= 194 CP= 1427.312
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:43:40  JAN 17, 2007 CP=   1430.438
    1  0.47212E-16    2  0.23095E-16    3 -0.82205E-17    4  0.21498E-16
    5  0.35903E-17    6  0.72655E-18    7 -0.36085E-16    8  0.60841E-16
    9 -0.52620E-15   10 -0.90614E-15   11  0.29841E-08   12 -0.65052E-06
   13 -0.16075E-05   14 -0.14066E-04   15 -0.13545E-06   16  0.13062E-07
   17 -0.12088E-03   18  0.11870E-06   19  0.15031E-09   20 -0.84169E-05
Solution Preparation Element= 1000 Cum.  Iter.= 195 CP= 1430.500
  Time= 0.0000 Load Step= 2 Substep= 175 Equilibrium Iteration= 0.
Solution Preparation Element= 42000 Cum.  Iter.= 195 CP= 1431.578
Solution Preparation Element= 75000 Cum.  Iter.= 195 CP= 1432.250
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:44:18  JAN 17, 2007 CP=   1435.344
    1  0.13764E-14    2  0.14809E-14    3 -0.93378E-15    4  0.17117E-14
    5  0.39238E-15    6  0.33828E-15    7  0.11892E-14    8 -0.19132E-14
    9  0.13153E-13   10  0.23344E-13   11 -0.14325E-05   12 -0.13395E-03
   13 -0.24086E-03   14 -0.13234E-02   15 -0.12154E-04   16  0.88004E-06
   17 -0.81186E-02   18  0.80011E-04   19  0.40848E-09   20  0.22452E-03
Solution Preparation Element= 1000 Cum.  Iter.= 196 CP= 1435.391
  Time= 0.0000 Load Step= 2 Substep= 176 Equilibrium Iteration= 0.
Solution Preparation Element= 56000 Cum.  Iter.= 196 CP= 1436.766
Solution Preparation Element= 95000 Cum.  Iter.= 196 CP= 1437.797
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:44:49  JAN 17, 2007 CP=   1440.609
    1 -0.15100E-14    2 -0.16475E-14    3  0.10404E-14    4 -0.18885E-14
    5 -0.43038E-15    6 -0.36479E-15    7 -0.11387E-14    8  0.17575E-14
    9 -0.11873E-13   10 -0.20886E-13   11 -0.12863E-06   12 -0.30715E-04
   13 -0.65408E-04   14 -0.50184E-03   15 -0.48100E-05   16  0.50637E-06
   17 -0.55899E-02   18  0.76066E-04   19  0.42683E-09   20  0.25546E-03
Solution Preparation Element= 7000 Cum.  Iter.= 197 CP= 1440.781
  Time= 0.0000 Load Step= 2 Substep= 177 Equilibrium Iteration= 0.
Solution Preparation Element= 52000 Cum.  Iter.= 197 CP= 1441.906
Solution Preparation Element= 92000 Cum.  Iter.= 197 CP= 1442.844
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:45:24  JAN 17, 2007 CP=   1445.688
    1 -0.28797E-13    2 -0.30937E-13    3  0.19504E-13    4 -0.35744E-13
    5 -0.81915E-14    6 -0.70414E-14    7 -0.24454E-13    8  0.39273E-13
    9 -0.26886E-12   10 -0.47709E-12   11  0.25916E-04   12  0.23694E-02
   13  0.42303E-02   14  0.22809E-01   15  0.20885E-03   16 -0.14614E-04
   17  0.13167       18 -0.12142E-02   19 -0.68587E-08   20 -0.31616E-02
Solution Preparation Element= 1000 Cum.  Iter.= 198 CP= 1445.734
  Time= 0.0000 Load Step= 2 Substep= 178 Equilibrium Iteration= 0.
Solution Preparation Element= 46000 Cum.  Iter.= 198 CP= 1446.906
Solution Preparation Element= 83000 Cum.  Iter.= 198 CP= 1447.812
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:45:58  JAN 17, 2007 CP=   1451.031
    1  0.44273E-14    2  0.34634E-14    3 -0.18837E-14    4  0.38338E-14
    5  0.84412E-15    6  0.65257E-15    7  0.13320E-14    8 -0.22218E-14
    9  0.12160E-13   10  0.22756E-13   11 -0.62383E-05   12 -0.63612E-03
   13 -0.11683E-02   14 -0.67072E-02   15 -0.61938E-04   16  0.46488E-05
   17 -0.42696E-01   18  0.34698E-03   19  0.78593E-08   20  0.39369E-03
Solution Preparation Element= 1000 Cum.  Iter.= 199 CP= 1451.047
  Time= 0.0000 Load Step= 2 Substep= 179 Equilibrium Iteration= 0.
Solution Preparation Element= 45000 Cum.  Iter.= 199 CP= 1451.953
Solution Preparation Element= 79000 Cum.  Iter.= 199 CP= 1452.844
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:46:35  JAN 17, 2007 CP=   1455.984
    1 -0.59610E-14    2 -0.73774E-14    3  0.49237E-14    4 -0.86658E-14
    5 -0.19599E-14    6 -0.17372E-14    7 -0.61260E-14    8  0.10017E-13
    9 -0.67530E-13   10 -0.11890E-12   11  0.61585E-05   12  0.57314E-03
   13  0.10297E-02   14  0.56527E-02   15  0.51916E-04   16 -0.37709E-05
   17  0.34978E-01   18 -0.35652E-03   19 -0.97130E-08   20 -0.10427E-02
Solution Preparation Element= 1000 Cum.  Iter.= 200 CP= 1456.000
  Time= 0.0000 Load Step= 2 Substep= 180 Equilibrium Iteration= 0.
Solution Preparation Element= 44000 Cum.  Iter.= 200 CP= 1456.922
Solution Preparation Element= 77000 Cum.  Iter.= 200 CP= 1457.781
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:47:12  JAN 17, 2007 CP=   1460.891
    1 -0.45550E-16    2 -0.81361E-16    3  0.58762E-16    4 -0.98078E-16
    5 -0.23306E-16    6 -0.21869E-16    7 -0.97709E-16    8  0.15401E-15
    9 -0.11280E-14   10 -0.19600E-14   11 -0.47940E-07   12 -0.66709E-05
   13 -0.13104E-04   14 -0.86457E-04   15 -0.81309E-06   16  0.71878E-07
   17 -0.71640E-03   18  0.69462E-05   19  0.15479E-09   20  0.11136E-04
Solution Preparation Element= 1000 Cum.  Iter.= 201 CP= 1460.906
  Time= 0.0000 Load Step= 2 Substep= 181 Equilibrium Iteration= 0.
Solution Preparation Element= 50000 Cum.  Iter.= 201 CP= 1462.172
Solution Preparation Element= 70000 Cum.  Iter.= 201 CP= 1462.703
Solution Preparation Element= 86000 Cum.  Iter.= 201 CP= 1463.203
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:48:00  JAN 17, 2007 CP=   1466.422
    1  0.10771E-14    2  0.11570E-14    3 -0.72945E-15    4  0.13383E-14
    5  0.30709E-15    6  0.26488E-15    7  0.93821E-15    8 -0.15126E-14
    9  0.10403E-13   10  0.18476E-13   11 -0.11538E-05   12 -0.10794E-03
   13 -0.19411E-03   14 -0.10666E-02   15 -0.97960E-05   16  0.70918E-06
   17 -0.65399E-02   18  0.64290E-04   19  0.30672E-09   20  0.17932E-03
Solution Preparation Element= 1000 Cum.  Iter.= 202 CP= 1466.469
  Time= 0.0000 Load Step= 2 Substep= 182 Equilibrium Iteration= 0.
Solution Preparation Element= 41000 Cum.  Iter.= 202 CP= 1467.359
Solution Preparation Element= 70000 Cum.  Iter.= 202 CP= 1468.219
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:48:42  JAN 17, 2007 CP=   1471.906
    1 -0.52807E-15    2 -0.57997E-15    3  0.36650E-15    4 -0.66280E-15
    5 -0.15073E-15    6 -0.12707E-15    7 -0.37908E-15    8  0.57474E-15
    9 -0.38558E-14   10 -0.67521E-14   11 -0.25327E-06   12 -0.32502E-04
   13 -0.63243E-04   14 -0.41463E-03   15 -0.39028E-05   16  0.35701E-06
   17 -0.37250E-02   18  0.46522E-04   19  0.24999E-09   20  0.14983E-03
Solution Preparation Element= 1000 Cum.  Iter.= 203 CP= 1471.922
  Time= 0.0000 Load Step= 2 Substep= 183 Equilibrium Iteration= 0.
Solution Preparation Element= 32000 Cum.  Iter.= 203 CP= 1472.766
Solution Preparation Element= 72000 Cum.  Iter.= 203 CP= 1473.891
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:49:25  JAN 17, 2007 CP=   1477.562
    1 -0.47827E-14    2 -0.51542E-14    3  0.32598E-14    4 -0.59876E-14
    5 -0.13789E-14    6 -0.11968E-14    7 -0.44172E-14    8  0.72041E-14
    9 -0.49745E-13   10 -0.88529E-13   11  0.65391E-05   12  0.62381E-03
   13  0.11284E-02   14  0.62941E-02   15  0.57939E-04   16 -0.43002E-05
   17  0.40286E-01   18 -0.41150E-03   19 -0.18243E-08   20 -0.11842E-02
Solution Preparation Element= 1000 Cum.  Iter.= 204 CP= 1477.641
  Time= 0.0000 Load Step= 2 Substep= 184 Equilibrium Iteration= 0.
Solution Preparation Element= 45000 Cum.  Iter.= 204 CP= 1478.641
Solution Preparation Element= 76000 Cum.  Iter.= 204 CP= 1479.125
Solution Preparation Element= 91000 Cum.  Iter.= 204 CP= 1479.609
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:50:16  JAN 17, 2007 CP=   1482.484
    1 -0.64208E-15    2 -0.79255E-15    3  0.53027E-15    4 -0.96205E-15
    5 -0.22948E-15    6 -0.21534E-15    7 -0.11020E-14    8  0.18944E-14
    9 -0.13653E-13   10 -0.24491E-13   11  0.32052E-05   12  0.32343E-03
   13  0.59500E-03   14  0.34637E-02   15  0.32094E-04   16 -0.25586E-05
   17  0.25107E-01   18 -0.29029E-03   19 -0.66938E-09   20 -0.95340E-03
Solution Preparation Element= 1000 Cum.  Iter.= 205 CP= 1482.547
  Time= 0.0000 Load Step= 2 Substep= 185 Equilibrium Iteration= 0.
Solution Preparation Element= 40000 Cum.  Iter.= 205 CP= 1483.516
Solution Preparation Element= 72000 Cum.  Iter.= 205 CP= 1484.391
ANSYS Multiphysics
00265231          VERSION=INTEL NT      09:50:54  JAN 17, 2007 CP=   1487.984
    1  0.36620E-14    2  0.36689E-14    3 -0.22445E-14    4  0.42194E-14
    5  0.97404E-15    6  0.83040E-15    7  0.29966E-14    8 -0.48574E-14
    9  0.33639E-13   10  0.60184E-13   11 -0.51273E-05   12 -0.49491E-03
   13 -0.89804E-03   14 -0.50439E-02   15 -0.46474E-04   16  0.34766E-05
   17 -0.32646E-01   18  0.33031E-03   19  0.22683E-09   20  0.92076E-03
*** NOTE ***                            CP=   1487.984   TIME= 09:50:55
Solution is done!
*** NOTE ***                            CP=   1489.391   TIME= 09:51:04
Solution is done!
FINISH SOLUTION PROCESSING
***** ROUTINE COMPLETED *****  CP =      1489.406
*** NOTE ***                            CP=   1489.406   TIME= 09:51:04
A total of 12 warnings and errors written to D:\bl\crank116.err.
NEW BACKUP FILE NAME= crank116.dbb.
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= crank116.db
  FOR POSSIBLE RESUME FROM THIS POINT
          ***** ANSYS RESULTS INTERPRETATION (POST1) *****
ENTER  /SHOW,DEVICE-NAME  TO ENABLE GRAPHIC DISPLAY
ENTER  FINISH             TO LEAVE POST1
*** NOTE ***                            CP=   1489.969   TIME= 09:51:07
The model contains an element type ( COMBIN14 ) that operates entirely
in the nodal coordinate system.  Viewing nodal displacements or forces
in other than the nodal coordinate system may be invalid.  See the
elements manual description for more information.
Reading results into the database (SET command) will update the current
displacement and force boundary conditions in the database with the
values from the results file for that load set.  Note that any
subsequent solutions will use these values unless action is taken to
either SAVE the current values or not overwrite them (/EXIT,NOSAVE).
  EXDY - numdof           6
exdy - node,numdof,nDofM  =       24952           6      149732
SPEC           1           1           1       31888           0
SPEC           2           2           2       31889           6
SPEC           3           3           3       31890          12
SPEC           4           4           4       31891          18
SPEC           5           5           5       31892          24
SPEC           6           6           6       31893          30
SPEC           7           7           7       31894          36
SPEC           8           8           8       31895          42
SPEC           9           9           9       31896          48
SPEC          10          10          10       31897          54
SPEC          11          11          11       31898          60
SPEC          12          12          12       31899          66
SPEC          13          13          13       31900          72
SPEC          14          14          14       31901          78
SPEC          15          15          15       31902          84
SPEC          16          16          16       31903          90
SPEC          17          17          17       31904          96
SPEC          18          18          18       31905         102
SPEC          19          19          19       31906         108
SPEC          20          20          20       31907         114
real numb. DOFs            20
*** MEMORY ERROR ***
An allocation was made with a negative length requested:          -38316
Blockname:GOA
Current ANSYS Traceback:
     write_exdy
     post1
     postcl
     slmenu
     ANSYS
A FATAL, DUPLICATE ERROR WILL FOLLOW THIS MESSAGE
*** FATAL ***                           CP=   1489.969   TIME= 09:51:08
Blockname:GOA.
TOP
Solution is done!说明ansys已经算完。
下面就是转换格式给EXCITE,这个接口规定,主自由度<5000个(动+静总和)。不知是否是你的主自由度超了,怎么会这么多呢?
我贴出来的机体和曲轴都能缩减吧?
TOP
虽然计算完了,可是out4后缀文件是0字节。我设的主自由度节点为31个,总共连了287个蜘蛛腿,每个主自由度节点上加了一个mass21单元,应该是没超阿。(动+静总和)什么意思?我是按照你给的接口说明设置的。
你贴出来的机体和曲轴都能缩减
谢谢蓝博士
TOP
如果方便,贴出来让大家检查一下吧。
静自由度就是保留节点自由度,动自由度就是模态个数。
TOP
谢谢蓝博士,我开个帖子把模型发上来............................................................................
TOP
请教
*** WARNING ***
请问蓝博士,这是怎么回事????
TOP
我也不知道啊。
TOP
发新话题
Google
搜索 WWW 搜索 SimWe.com
baidu
搜索 WWW 搜索 SimWe.com
